12-22-2015 08:01 AM - edited 12-22-2015 10:27 AM
My5620 connects to the access point with either connection method, password or pushbutton, but the printer doesnt appear in the printer list when I run the setup guide from the cd. Using Windows 7. Could there be a problem with the modemsettings? It was replaced recently.
Thanks for any help
12-24-2015 10:52 AM
Hello.
Check to make sure that your computer is connected to the same Wi-Fi network as the printer. If you have a router that uses both 5.0GHz and 2.4GHz frequency bands, connect your computer to the 2.4GHz network since our printers cannot connect to a 5.0GHz band.
If the issue continues to persist, find more help at Contact Us.
