02-10-2014 10:53 PM
I have a Toshiba laptop with Windows 8 64 bit. I am able to successfully install, make a connection to my MX340, and print a test page.
Any time there after though when I try to print Windows says the printer is offline even though the printer is on.
I have gone through this process several times and each time it happens the same (definition of insanity, right?).
Anyone else having this same experience with Windows 8?
Thanks in advance,
Tim
02-10-2014 11:03 PM
After searching the forum for Windows 8 seems it is a common problem trying to use the Canon printers wirelessly.
I found this thread and I am going to try the suggestion of manually adding the printer to Win 8 using the ip address.
Hopefully this fixes my problem
btw, the printer works fine for me in Windows 7.
02-18-2014 10:53 PM
Well, I tried following these instructions, but no success yet.
Go into your printer and print out your Network Configuration, then use windows 8 to connect to it by IP address manually (DO NOT use the cannon software if running windows 8!!!) In windows 8 go to add a printer and after it doesnt detect it, you will then be able to add by name/ IP or manually. I select IP and set mine up within 1 minute.
When I went to "add a printer" windows detected my printer so I don't know if that changed things.
02-24-2014 11:04 AM
Update: I have gone through the steps of adding my MX340 as a tcp/ip printer but still no success.
At this point, I am ready to toss Windows 8, my MX340, or both out my window.
Win 8 connects but just will not print. The request from Win 8 just goes into the bit bucket never to be seen again.
02-24-2014 11:25 AM
Hi d503364!
Thanks for posting in the Canon Forum! The Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team.
Thanks!
04-26-2014 11:13 AM
Hello d503364,
Did you install the printer driver using the CD or download the driver from our Website?
04-28-2014 10:03 AM
I have only used the drivers provided in Windows 8 to install my Canon MX340 printer to be able to print wirelessly.
My understanding was that was what Canon said I am supposed to use.
Are there Canon MX340 printer drivers I can install that may resolve this issue?
By the way, the printer works whenever I connect via the usb cable.
Thank you for your continued support.
Tim
