05-02-2019 02:48 AM - edited 05-02-2019 02:54 AM
05-03-2019 05:06 AM
Hi Ninjaman,
I understand that you have encountered issues printing over the network; however, you are able to print using the Bluetooth. I recommend resetting the printer followed by connecting the printer to the network. The following steps will assist you with communicating with the printer over the network:
Resetting the Printer
Now that the unit has been reset, next is connecting the printer to the network using the Manual Connect method. You will need your network name and password for this part.
Connecting the Printer to the Network
Now that the printer is connected to your network, confirm that the printer and the device you are printing from are on the same network and perform a test print.
If you are unable to print, printout the printers network configuration page. Click HERE for information on printing on the network configuration print. Review the network configuration page for the following information:
If you do see an IPv4 IP Address, and it starts with a 192, 172, or 10, please do the following:
05-03-2019 05:06 AM
Hi Ninjaman,
