08-15-2015 01:48 PM
Still looking for 8 digit pin number Canon MG7520 printer wants? Looked for 2 hrs for the WPS button was on router and not the printer. Horrible instructions. I just want wireless printer for my devices on network not a access point printer. I have windows 10
08-17-2015 11:02 AM
Hello.
If you are having troubles with locating the WPS pin for your router, you can try using the Standard setup process. Please follow these steps:
1. Go to the Home menu or press the Home button.
2. Use the up or down arrow keys until Setup appears, then select Setup.
3. Select Device Settings.
4. Select LAN Settings.
5. Select Wireless LAN Setup. If prompted to use the WPS method, press the STOP button on the printer.
6. Select Standard Setup.
7. Follow the remaining prompts to connect the unit to your router.
Once this has been done, visit our website at this link to download the Windows 10 drivers for the printer.
