Unable to get PIXMA MX922 to Recognize Router
Deleted021121a
This is a new install...Recently purchased PIXMA MX922 and have not been successful in getting to recognize my router. Steps I took:
1. Menu --> Search for Access Point --> once engaged it times out.
2. My second attempt involved...Menu --> Change set up method --> Other setup ---> Advanced setup --> My access point is not displayed in the menu. I searched several times to no avail.
3. Last Attempt: My third attempt was to enter the name directly. The result was the same - access point was not found.
Any ideas on what I might be doing wrong?
1 REPLY 1
Waddizzle
I have no idea what it might be doing wrong..
Check your security settings in your wireless router.  Make sure that it is not setup to only allow connections to a list of valid MAC addresses.  If so, disable it until you get connected, and can add the printer's MAC address to the list.
