05-30-2019 04:12 PM - last edited on 12-01-2022 01:49 PM by Danny
Hello Experts,
I have a friend with a Pixma MG3620 that was set up by someone else a few years ago on a wireless network. My friend changed ISPs a few months ago and now has a new router, but his printer was never set up to connect to the new access point.
Since the printer does not have a display panel, I can't quite figure out how to connect it to the new router. I looked at the documentation online, but I'm not seeing where those steps are.
How can I connect the printer wirelessly to the new access point/router? Can I change it, or do I need to manually reset the printer to its factory setting so that I'll be prompted to re-connect?
Thank you in advance for any assitance.
05-31-2019 02:59 AM
Hi gtifeld,
Shadowsports provided some excellent information on connecting the printer to the network using a computer.
Another option available is using an Android- or Apple-supported mobile device to connect the printer to the network. The steps below will assist you:
On the Printer
On your Mobile Device
If the setup fails, please unplug your router for approximately 1 minute. Once the router is plugged back it, after approximately 2 minutes all devices should be back up on the network. Perform the wireless setup one more time.
05-31-2019 02:59 AM
Hi gtifeld,
On the Printer
05-31-2019 12:39 PM
09-08-2019 03:19 PM
I have a PIXMA TS8120 Canon printer. I changed my router just a few days ago. I tried easy wireless connect. That site did not help. I just want to change my router settings in the Canon Printer. How can I accomplish this?
Appreciate your help.
12-10-2020 06:21 AM
TS3160
i just purchased the new printer however someone has set an wifi password on the printer. How to remove it or reset it? I have tried to follow the steps but didn't work.
12-17-2020 03:58 PM
Hi Choyu90,
To connect your PIXMA TS3160 to your wireless network, please follow the steps on this page (the model is different, but the steps are the same):
https://support.usa.canon.com/kb/index?page=content&id=ART167967
01-06-2021 01:51 AM
The Printer's wifi is not always visible. I connected to it and then it disappeared. Is there another way to connect my printer to the new wifi router I have.
Thank you
01-10-2021 05:57 AM
How do I know the password for Canon network?
05-15-2023 09:18 PM
I just set up as new router. When I press the wifi button, the power button doesn't flash. I've held it down for a minute. The button under it that flashes when there is a problem will start to flash instead of the power button.
Thanks!
09-22-2023 05:21 PM
I didn't find this to be helpful. I tried resetting my printer's network on both my iOS device and Android and it didn't work. As soon as it would find my network, it would disconnect and wouldn't finish.
I ended up finding the desktop setup software: https://support.usa.canon.com/kb/index?page=content&id=ART162917 and was able to set up my printer after connecting it to my computer with a USB cable.
I hope this helps other people who have the same issue.
11-02-2023 07:04 AM
Also, Click Here for Canon Pixma Printer Setup with Wi-Fi
