PIXMA MX920 Printing blank pages
linniebooc
I have a Canon MX920. About 6 months ago (I don't print that often) I purchased a new computer and had the printer connect wirelessly to the computer. I didn't have any issues with it recognizing it but when I try to print to it today I just get blank pages. Even when I do the nozzle test it just prints out a blank page. I also cleaned the nozzle and I'm still getting the same issue.
Any suggestions?
4 REPLIES 4
inkjet printers do not do well when they sit unused for long periods of time.
The absence of a Nozzle check pattern after a standard and deep cleaning task indicates a problem with ink delivery or the printhead.
Multiple cleanings might help:
https://ugp01.c-ij.com/ij/webmanual/Manual/W/MX920%20series/EN/BG/Bg-Maintenance1000.html
But you don't want to repeat this more than twice as the ink won't have anywhere to go if the head is completely clogged.  What you'll get is a big mess.
Perform the test from the control panel:
https://ugp01.c-ij.com/ij/webmanual/Manual/W/MX920%20series/EN/BG/Bg-Maintenance1200.html
This will rule out anything to do with the driver or type of connection.
If nothing comes out, you may want to try removing the printhead and cleaning it manually.
~CarePaks Are Worth It
How do I clean the print heads manually?
Hi linniebooc.
Canon only recommends cleaning the print heads by performing the cleaning and deep cleaning options. You can use the link shadowsports provided above.
Robin7888
Hello,
First, please check if the printer add-on is enabled or not.
  • First, press the Windows key + Letter R and Run windows will open
  • Now type inetcpl.cpl then click on OK to run the comment
  • Then go to the Programs tab and please check the printer add-on and check whether it is enabled or not.
  • Done now; please print a test page using an online tool and check whether everything is working fine.
Thanks
Enter for a chance to win!
April 20th-28th
