09-13-2013 11:22 AM - edited 09-15-2013 01:41 PM
Hi JJo,
With some routers, if activity is not detected on a device after a set period of time, the device will be removed from the routing table. When the printer enters standby, it also enables discontinuous reception to save power. This might cause the printer to be disconnected from the router when you attempt to print again.
To disable this feature:
If the device is still disconnected after a long period of inactivity, I recommend contacting your router manufacturer for some additional options or settings you can change within the router itself.
10-31-2013 01:40 PM
I have connectivity issues as well. It's not the router. Turn off printer, unplug, nothing helps. It works fine for a while. Don't even know what ever happens for it to connect again... It just goes on and off... now it's off and I can't print! Very frustrating! Not showing up on my iphone when I have it right next to the printer so it's not signal strength! Won't print from laptop in next room either.
10-31-2013 11:31 PM
11-02-2013 05:04 PM
Add me to the list. Printer was working fine for a month or two, now the PC can't find the printer. The printer appears on my router's list of connected devices,and I can ping it from my computer. The printer just won't talk to anything over the connection. I reset all, reconnected, re-installed the printer, all with no more connection. Going to try the USB cable, at least that may save me from throwing the whole thing away.
11-11-2013 01:20 PM
Hello.
For additional assistance with this matter, please contact our technical support group. Please visit the following link below:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
11-12-2013 02:07 PM
My print out says SIGNAL STRENGTH is 100%. Still not able to print with the MG5350.. Any other advice?
11-12-2013 06:11 PM
I found if the printer goes offline I have to go into the menu and key in the password to get the connection back...
11-19-2013 09:53 PM
My Airprint will only connect for about 10 seconds. This is so annoying
01-24-2014 11:55 AM
Upgrade your router to wireless N. It needs the newer technology for a stronger wireless signal.
01-24-2014 11:56 AM
