Reply
Highlighted
New Contributor
PIXMA MX922 Cloud Print not working
I have been unable to use Cloud Print for well over a year now; I've tried every "fix" that I've read both here, and in other forums, with no luck.
Today I got a new router, so I decided to start poking about again, and I still can not use Cloud Print.
From the Cloud Print homepage, I deleted my printer, then from the printer went to register again and received a "cannot connect to server" error.
Googling that for a bit, I came across a post on the Canadian Canon page regarding the issue which stated that the MG6320, MX522, MX722, and MX922 were getting a new firmware to correct the issue; that post was from December of 2015 ... when will this issue get fixed!?!
I feel completely ripped off having bought this printer brand new, and only having the Cloud Print feature work for less than a year.
Highlighted
New Contributor
Re: PIXMA MX490 Cloud Print not working
I just bought a Canon pixma mx490 and can't get it to work either with my tablet
Highlighted
Reputable Contributor
Hi gsmitchell!
To have a better understanding of your issue, please let everyone the type of tablet you are using.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bitly.com/CanonEmail or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
Highlighted
New Contributor
Re: PIXMA MX922 Cloud Print not working
My tablet is a lg gpadX10.1
Highlighted
Hi gsmitchell,
First, please make sure that your PIXMA MX490 is operating on your wireless network:
1. Press the <Setup> button on your PIXMA MX490.
2. Use the left or right button to select Device Settings and press <OK>.
3. Use the left or right button to select LAN Settings and press <OK>.
4. Use the left or right button to select Wireless LAN Setup and press <OK>.
5. Use the left or right button to select Standard Setup and press <OK>
6. Enter your wireless network password and press <OK>. Please verify the password, as it is case sensitive and if entered incorrectly, will cause the printer and router to not communicate. To switch between letters and numbers, press the * key.
7. Press <OK> on the confirmation screen. The PIXMA MX490 will search for the access point.
8. When found, press <OK> on the Connected to the access point screen.
Once your PIXMA MX490 is connected to your wireless network, please view this PDF to set up your PIXMA MX490 for use with Google Cloud Print on your tablet:
http://downloads.canon.com/cloud/MX492_UseGCP.pdf
powered by Lithium
