11-19-2018 09:51 AM
Hi, I switched out by buggy Apple router for a Google Home Wi-Fi system. (Looks like a disc with a blue light.) I can't figure out how to connect my 6220 to the Wi-Fi network, and Google support says Canon would have to provide the answer. Canon no longer offers support for this model. Hoping someone has an answer, even if it's "Buy a new all-in-one." Thank you.
11-21-2018 02:36 PM
Hello.
Perform the following steps to connect the printer to your network:
1. Go to the Home menu or press the Home button.
2. Use the up or down arrow keys until Setup appears, then press the softkey under Setup.
3. Select Wireless LAN Setup and press OK.
4. If prompted to active the Wireless LAN, choose Yes and press OK.
5. Select Other Setup and press OK.
6. When your access point appears, select it and press OK.
7. Enter your encryption key and press OK.
8. Confirm the key is correct and press OK.
9. Once the connection is complete, press OK.
Once this has been done, ensure that your computer is on the same network as the printer. Then try printing to test the connection. The computer may need to be restarted as well.
