Reply
New Contributor
PIXMA MG5720 will not connect to wifi router
.Will not accept password.  Firmware is up to date.  Thoughts?
Re: PIXMA MG5720 will not connect to wifi router
Hi bcomito,
To set up your PIXMA MG5720 on your wireless network, please follow these steps:
1. On your PIXMA MG5720, please press Setup from the HOME screen.
2. Select Device settings and press OK.
3. Use the up or down arrows to select LAN settings and press OK.
4. Use the up or down arrows to select Wireless LAN setup and press OK.
5. Select Other setup and press OK.
6. Select Advanced Setup and press OK.
7. Select your access point (router name) and enter your wireless password. Please make sure that the password is corrrect. The password is case sensitive, if entered incorrectly, your PIXMA MG5720 will not connect to your wireless network.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
New Contributor
Thank you for the information.
I followed the steps but after I get to "Other Settings" there is no "Advanced Settings" option. I can choose from:
Set Printer Name
TCP/IP Settings
WSD Settings
Bonjour settings
LPR protocol settings
PictBridge Communication
Direct connection settings (greyed out, not able to select)
Please advise.
Hi klongbaker,
Please try Standard Setup instead:
5. Select Standard setup and press OK.
6. Select your wireless network from the list that appears and press OK.
7.  Enter your wireless network password and press OK.
Your PIXMA MG5720 should now be connected to your wireless network.
Please note, Canon's Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. If this is an urgent support need, please use the link below to reach our friendly Technical Support Team:
New Contributor
I can go through those steps just fine. My issue is my internet is password protected - but when selecting on the printer it begins to try to connect without a prompt to imput the password. So the result, it tries to connect and then gives me an error message. Not suprising as I was unable to provide the password.
powered by Lithium
