02-18-2013 02:58 PM
Hi, I am trying to print to my MG5220 printer, and I'm having some serious problems.
Basically, I setup my printer and connected it to my wi-fi network, then I installed the drivers on my computer, restarted, and attempted to add the printer. The printer search was unable to find the printer on the network, and after canceling my 2nd search, my connection became extremely unreliable. I couldn't reload websites, I couldn't connect to anything, and I couldn't see my network. Restarting did nothing, disconnecting all other devices did nothing. The only thing that fixed the problem was to uninstall the Canon drivers and restart the computer.
Here's the weird thing, this happens for ALL the printers in my house, on my computer, and my brother's computer. I have a PIXMA MX870 a PIXMA MX882, and a PIXMA MG5220. These computers work fine on the Powerbook and iMacs I have, but not on my Windows 7 64bit computers.
Every single time I try to install the drivers for my Canon printers, it completely destabalized my internet connection and my computer until I uninstall the drivers.
Why is this happening, and what can I do to fix it?
02-25-2013 10:49 PM
Hi Drinfested,
The Windows Firewall could cause this to occur. To temporarily disable the Windows Firewall, please follow these steps:
1. Click on Start and then Control Panel.
2. Click on Security Center and then Windows Firewall.
3. Select OFF and then click OK.
Once set, please attempt to print. If the issue persists, please try this:
1. Select [Setup] from the HOME screen on your PIXMA MG5220.
2. Press the right arrow key to select Device Settings and press OK.
3. Press the down arrow key to select LAN Settings and press OK.
4. Press the down arrow key to select Confirm LAN settings and press OK.
5. Press the arrow key to select WLAN Setting list and press ok.
The IP address will be in this list, please copy the address down on a piece of paper. On the computer, please follow these steps:
2. Click on Printers.
3. Right click the PIXMA MG5220 and left click on Properties.
4. Click on the Ports tab.
5. Click the Add Port button.
6. Choose Standard TCP/IP Port.
7. Click New Port.
8. In the wizard, click Next and then type the IP address of your printer in the box.
9. Click Next.
10. Click Finish.
11. The checkmark should be next to the port that we just created. If not, please checkmark it.
12. Click Apply and OK.
The issue should be resolved. If it is not, then we should try reinstalling the software. To perform the uninstall, please have the PIXMA MG5220's CDROM in the CDROM drive and then follow these steps:
1. Click on Start and then Run. If Run is not in your Start menu, please follow these steps to add it:
1-1. Click Start.
1-2. Right click the Start menu and left click on Properties.
1-3. Click on the Customize button next to 'Start Menu'.
1-4. In the Customize Start Menu window, place a checkmark next to 'Run Command'.
1-5. Click OK in the Customize Start Menu window.
1-6. Click OK in the Properties window.
2. Click Browse. In the browse window, click on My Computer.
3. In the window to the right, double click the CANON_IJ CDROM.
4. Double click the folder named WIN.
5. Double click the folder named Driver.
6. Double click the folder named DrvSetup.
7. Double click the file named DELDRV64. In the Run box click ok.
8. Click Execute to start uninstall and Yes to completely uninstall the drivers.
9. Once finished, click on Start and then Run.
10. Click Browse. In the browse window, click on My Computer.
11. In the window to the right, double click the CANON_IJ CDROM.
12. Double click the folder named WIN.
13. Double click the folder named Driver.
14. Double click the folder named LAN.
15. Double click the file named CNMNPU.exe
16. In the Run box click OK and then Yes on the Delete BJNP Port window.
17. The uninstaller will prompt you to restart the computer, please click Yes to restart the computer.
To install the unit for use over your network wirelessly, please follow these steps when the computer restarts:
1. Use the up or down button on your PIXMA MG5220 to display Setup and press the right FUNCTION button.
2. Select Wireless LAN Setup and press OK.
3. Select Yes and press OK.
4. Select Easy Setup and press OK.
5. Select your access point name and choose OK.
6. Press the right FUNCTION button on the Enter passphrase or Enter WEP screen.
7. Enter your WEP or passphrase and press OK.
8. Make sure network key is correct and press OK.
9. When the connection confirmation appears, press OK.
10. Take out and then reinsert the CDROM that came with the PIXMA MG5220. The setup program will start
automatically. If the Autoplay screen appears, click Run and then Continue.
11. Click on Easy Install.
12. When the Easy Install screen appears, click Install.
13. Select Use the Printer on Network and click Next.
14. If it appears, please read the License Agreement carefully and click Yes if you agree.
15. Click Next at the Printer Detection screen.
16. Select your PIXMA MG5220 in the Detected Printers List and click Next.
17. On the Canon IJ Network Tool screen, select the PIXMA MG5220 and click Next.
18. Confirm the results and then click Finish to complete the installation.
