Reply
New Contributor
Re: Now that Google Cloud Print is going away how do I get my MX922 to connect to my Chromebox wirel
Hello, can yo send me the ppd file? I have an MX920 and cant seem to find a solution to print.
Occasional Contributor
     I sent you a PM.
     I've also made the file info available on r/chromeos on Reddit.  You can just search for "Canon MX922 PPD" and it should come up in the results.
New Contributor
Thank you so much. I'll give this a try!!
New Contributor
I have the same issues on all three student chomebooks that used to print to my Pixma MX472.  Any suggestion on how to get reconnected?  I've tried the IP based method and it didn't work.  Would the PPD file that everyone is mentioning work on my MX472?
     Probably not.  I'm no expert on this by any stretch of the imagination but it seems that it looks to make sure it's printing to the correct sort of printer that is in the PPD file.  So you'd need to get the name of the printer that is being advertised and place that into the file just to even begin to test if they're further compatible (I'm guessing they're not without actually looking).
     If you really want the file I can PM you the link (or you can search for it on Reddit) and you can try it as-is simply because you have nothing else and it won't hurt anything (you can just remove it).
New Contributor
Hi, may I have the file too? I have a canon mx922
     I sent you a PM.
New Contributor
Can I also get a copy of the PPD? Thanks so much!
     I sent you a PM as well.
New Contributor
Thank you!
powered by Lithium
