02-16-2021 03:43 PM
I recently changed my Wireless Router and now my printer won't connect to it.
I believe the problem is in the Network Configuration of the printer. The defaut gateway of the new router is 192.168.50.1 and the IP Address on the Canon iP7220 printer Network Configuration Page is 192.168.0.185.
Since I have many other devices connected to the router I can't change the IP Address of the default gateway. What I need to do is either change the IP Address of the printer in the printer Network Configuration or do a Factory Reset of the printer
Does anyone know how I can either clear the Network Configuration Page in the printer or do a factory reset of a Canon iP7200 printer?
02-16-2021 04:02 PM
Hi The_Hat,
The iP7220 should not have to be reset in order to connect it to your new router. Please try using the WPS method to connect your iP7220 to your wireless network.
02-16-2021 04:02 PM
Hi The_Hat,
02-16-2021 04:09 PM
Hi Patrick,
That is one of the things I tried before I submitted a New Topic.
Previously I tried installing a new driver but that didn't work. I was going to try connecting the printer using a USB connection however I no longer can find the USB cord designed to be used with the printer. I bought this printer over 10 years ago andI can no longer find the cord.
02-17-2021 04:02 PM
Hi Patrick,
As usual things happen with Windows 10 that I find hard to explain. After replying to you yesterday, today I had the occasion to uninstall another totally unrelated application.
After completing the uninstall it was necessary for me to "Restart" my computer and when I did my Canon started printing all of the documents that were in queue.
With that I'm happy to say your directions were in fact the "Best Answer" and I thank you for responding to my request.
