Reply
New Contributor
Re: My computer can't find the printer on the network (PIXMA MG5420 with Windows 7)
[ Edited ]
With a Canon MG6620 the printer can never be detected when using "mp68-win-mg6200-1_02-ejs.exe" version driver. This used to be the driver listed here:
https://www.usa.canon.com/internet/portal/us/home/support/details/printers/inkjet-multifunction/mg-s...
but it has since been replaced with the driver that always worked which is version "mp68-win-mg6600-1_01-ejs.exe"
Bottom line use an old version of the driver or look here: https://www.usa.canon.com/internet/portal/us/home/support and find the driver for your model and try again. Since Canon removed the not working 1.02 driver version for the MG6620 it is likely they also removed the driver that was causing problems for other models.
New Contributor
Same problem as others here - on new laptop (Windows 10) tried to connect to my MX922 - showed up as my default printer but would not print. I finallly followed recommendation in earlier post to link to Canon site and download drivers (autodetected) for Windows 10. While I had no luck linking to printer from downloaded file via Wireless LAN, I found success by following last-ditch instructions to download to printer by USB - this worked without any hitch and I now have full wireless LAN printing function.
New Contributor
This is an old thread, but I'm going to add my 2 cents and a possible solution.
I've got a Pixma MG5320 which was working fine via WiFi before I got an Asus RT-AC88U router. For whatever reason, the router just doesn't let the printer connect. The odd part is that the printer settings look fine and even acquires a proper IP address. My solution was to connect my old router behind the Asus router and connect the printer to the old router's WiFi. This instantly solved the problem. I've posted more in-depth details here: http://www.seriouslytrivial.com/2017/07/04/canon-pixma-mg5320-not-compatible-with-asus-rt-ac88u-rout...
Occasional Contributor
1. Goto Device Manager and Uninstall the printer. Disconnect printer from computer (unplug).
2.reboot
3.Connect the printer to computer. Windows will 'find' the new device (msg in lower right corner) and find its driver (if windows has one in its database) or it will open the installation window. Don't let it search online, direct it to the folder/drive where the (downloaded) driver resides.
4.Make sure that you have proper drivers installed on your system
Regards,
Christian
Highlighted
New Contributor
Hey I had the same issue after checking that everything was connected I decided to unplug my router and modem and just let it restart it set again. Then it magically started to work again. After a hour of seeing that the printer was connected wirelessly and all drivers wear installed. It just needed to be restarted by unplugging the modem and router and plugging it back on. Problem solved for me
New Contributor
I have been having with my Printer connecting through wifi, been through all the troubleshoot options but nothing seems to work. The printer works fine and the issue only arised when I changed routers because I changed internet provider. I now have to print through USB which is a little bit of a pain as the printer isn't so close to the pc. If there is anyway to fix this it would be great. Aslo I am on windows 10.
powered by Lithium
