Reply
Highlighted
New Contributor
Re: My computer can't find the printer on the network (PIXMA MG5420 with Windows 7)
Note this is a Windows 10 installation.
Update:
I have two Canon wireless printers that stand side by side. Both are powered on and both show the blue Wi-FI indicator. Settings for both are idenical.
1. Canon MX922 wireless connects to the network and my PC. It functions correctly.
2. Canon MG5420 wireless does not connect to the network or my PC despite repeated completion of all troubleshooting steps. It remains invisible to my PC. It can print when connected by USB cable.
Turning on Network discovery was a good idea, but it was already on.
Still looking for a solution, For example: "your printer's the wireless hardware (or software) is defective and needs to be replaced. Here's how to do it..."
New Contributor
I just bought the MX532 and I am having the same problems with connecting the printer to the Internet. I have gone into my router security and ensured that it is broadcasting with the same encryption as the printer but no success as of yet. I saw on line that it is recommended to set up the printer with a windows computer will that do it?
Doug
Hello.
Troubleshooting with our support group will be needed to narrow down the causes of your issues. Please contact our support group using the "Contact Us" link below for additional assistance.
New Contributor
I was able to contact Canon here in Canada and the service representative was extremely helpful.
The problem was that I have a Rogers Hitron dual band modem/ router and the IPv6 was not turned off so the printer did not get an IP address assigned to it. If you have the same modem/router and are trying to connect your wireless printer try setting the IPv6 to inactive.
Hope this can help others.
Cheers!
Doug
New Contributor
Possible solution for all the Mac Users, using parlells .
Change the network settings in the Device Menu to Bridged Network instead of Shared Network.
Occasional Contributor
It is very distressing to see that this is a known problem and it has never been adequately corrected.
I have a brand new Pixma MG5720 to replace a previous Pixma which died much too soon. This one may be going back to Micro Center any minute, but for now, I too am stuck with a printer that the computer can't find on the network after going through all the responses here. Is there any answer or should I just give up and return it?
New Contributor
Hi Mike,
Maybe I can help.
Can you tell me if if the Windows 7 Machine is a virtual machine running on a Mac, or if it is a standalone machine?
That's left over from the previous posts. I have a Mac and I'm not running any form of Windows, but this thread describes the problem which is that although I got the printer to find the network, the computers cannot find the printer on the network. I've followed nearly all the advice above, but gotten nowhere.
New Contributor
I ampresuming the printer is successfully connected to the network and you can get it to print the network information.
What is the ip address of your printer and what is the ip address of you mac.  Do they start with 192.168 or 10.0?
The reason Why I ask is, with my issue my Mac has a habbit of bridging the network, so I was trying to install the printer on one local network (exclusive to my macBook), and the printer was on my office network.  Two separate networks, and therefor could not see the OS/ printer install could not see the printer.
The printer itself confirmed that it successfully connected to the network, yes. I haven't made it print anything.
The IP starts with 192.
I had an earlier Canon that did all this just fine, no hassles.
powered by Lithium
