Reply
New Contributor
Re: Mx920 Wireless printing problem
Heppened again to me the other day. Printer not available to computers over wireless network. This time, thr router appeared fine (green LED indicated normal), but I restarted it anyway. That solved it, until next time!
Success after restarted (power off/on) wireless router.
Occasional Contributor
I called the customer support. The basic solution for me was to shut off printer, then unplug router (Time Machine) then wait 30 seconds plug it back in and then turn on printer and renter access pint password. I have Mac that runs Yosemite. Although a pain it seems that when router updates or power outage things need to be restarted. Solves problems.
thank you for helping.
New Contributor
I don't know if you read all of the posts on this topic, but this is the solution that worked for me (excerpt from message #90):
"The solution that worked for me so far was to go through the printer setup process again, select the access point, and enter the password."
I hope it works for you as well.
Yes - thanks, but I have totally uninstalled and reinstalled twice - going through the whole Canon menu set-up sequence each time.  I can figure out a way to manually scan an image to my desktop, then drag it into an email.  But I used to be able to get an image directly scanned into an email...in other words, an email would pop up on my PC screen, ready to be filled in with subject and  recipient's name. Now when I punch the scan button on the printer screen, the only option is "Attach to E-mail Local (USB).  There should be a way I can select that message then scroll to another option to use Wifi instead of Local USB. I cannot, however, get to that particular message by punching the up arrow. Just get the little bell-type signal that that action is not valid.
New Contributor
I found this on some Canon support site where they responded to a customer. It worked for me!! I have been doing the reinstall, reboot, readd wifi bs forever:
a) Press “Windows Logo” + “R” keys on the keyboard to open the “Run” command box.
b)Type “Services.msc” in the “Run” command box.
c)In the “Services” window, double-click on “Print Spooler” service to open the properties window.
d)Stop the service, if it is already running and then restart the service by clicking on the “Start” button.
e)Now, select “Automatic” from the “Startup type” drop menu.
f) Click on "Apply” and then “Ok”.
g)Close the “Services” window and restart the computer.
h)After the restart, check if the issue persists.
so I have come to the conclusion that it is how the printer and the router connect with each other and in the end, as ridiculous as it may be, the fault can be placed on the router for not playing nice with the printer...or the printer with not having the ability to offer a universal communication between routers regardless of manufacture
I had wifi connection (or lack there of) issues when I had internet with rogers and their modem/router. I then switched to Bell and used their modem/router. No issues what so ever. It was a great 6 months printing wise. Static IP assigned, able to print from multiple systems and devices - ipad, iphone, macair, windows pc.
Just switched back to rogers with their modem/router - wifi connection issues again. My only option is to set the modem/router to bridge mode then add an additional router. Really irritates me that I have to introduce an extra piece of hardware when this really should not be a problem.
Highlighted
New Contributor
There are a lot of things in this thread that I would like to try.  If I could print them without carrying my laptop into another room and connecting it with a USB cable, it would be great.
New Contributor
BTW, the current firmware for this seems to be 3.0 and can be downloaded from the printer as some of the above instructions demonstrate.  However my printer still does not work wirelessly.
New Contributor
For the moment, I can see the printer from my MacBook, My wife's MacBook, and my iPhone and iPad.  I don't know when the 3.0 firmware was released, but I sure hope I can come back next week (or even tomorrow) and say that this is still working.
powered by Lithium
