08-07-2013 08:16 PM - edited 08-07-2013 08:18 PM
09-12-2013 11:27 AM
Hi DJcamp,
Since you are able to connect to the router without security enabled, there appears to be something on the router blocking the communication between your printer and computer. I recommend checking with your router manufacturer for setup suggestions or to see what additional security features are enabled when you use the WPS feature.
If your computer is connected to the router and you have a USB cable available, try the setup process again using the cable temporarily. This will transfer the correct SSID and passphrase from your computer to the printer to allow the two devices to connect to the same router/network.
For more information on how to perform this setup, view one of the following articles from our Knowledge Base:
How to perform the wireless setup using a USB cable (Windows)
How to perform the wireless setup using a USB cable (Mac OS X)
