09-04-2019 12:18 AM
Printer was working fine until suddenly it can't connect to WiFi. Jumped through all the hoops ( Manual setup, standard Setup, holding button on WPA) but still no luck connecting to access point. It sees my network, but I enter password and it times out. We've had the same password for years, and I've confirmed that isn't the problem. Why isn't it connecting? This printer is less than one month old 😞
09-06-2019 01:16 PM
Hi ladyaoi2001,
Who is the manufacuter of your router and what model number is your router?
09-07-2019 12:02 PM
It's an XFinity XB3 Router
09-09-2019 04:20 PM
Hi ladyaoi2001,
Please try the steps below to disable the ipv6 setting on the printer. Once that is done, perform the standard setup on the printer in which you select your network name and enter the password.
09-10-2019 12:07 AM
Still no luck. Any more ideas?
09-10-2019 02:24 PM
09-11-2019 07:42 PM
I'm not seeing the March 10 post that discusses the static IP? If you see it, could you please copy/paste?
Thank you!
I'm out of options.
09-11-2019 11:50 PM
09-12-2019 12:24 AM
That's a little bit over my head. I'm not sure what the static IP address is, let alone how to enter it on the printer.
09-12-2019 11:59 AM
