Reply
Highlighted
New Contributor
MG3200 Printer Offline. Intermittently prints over WiFi
I have a Canon MG3200 that intermittently prints over WiFi. I frequently get the message that the Printer is Offline. Sometimes, several restarts of the printer and/or router and/or computer will get it to come back online, but there appears to be no combination of restarts that gets it to work every time.
I have re-installed the printer drivers ad nauseum from the original installation disk, directly from Canon, and using the generic Windows drivers. None of these have solved the problem. I do not have a problem printing from this computer to any other printers over WiFi. I had this same problem with this printer on my previous computer running Windows 7 and was never able to resolve it.
My OS is Windows 8.1 Pro. What do I need to do in order to diagnose and fix this problem?
Highlighted
Re: MG3200 Printer Offline. Intermittently prints over WiFi
Hi schro_cat,
Please make sure that there is a strong signal between your printer and the wireless access point.  To do this, please follow these steps:
 1.  Open the Canon IJ Network Tool.
 2.  Select the printer in Printers.
 3.  Select Status from the View menu.
The Signal Strength indicates the strength of the signal received by the printer, ranging from 0% to 100%.
the Link Quality indicates the signal quality excluding the noise while communicating, ranging from 0% to 100%.
Both of these values should be as close to 100% as possible.
Make sure that there is no barrier or obstacle between the access point and the machine. Wireless communication between different rooms or floors is generally poor. The metal, concrete, or timber including the metallic material, mud wall, or insulator may interrupt a wireless communication. If the machine cannot communicate with the computer over a Wireless LAN for the wall material, place the machine and the computer in the same room or floor.
Since a device such as a microwave oven uses the same frequency bandwidth, it may cause interference. Place the wireless devices as far away from the source of interference as possible.
Also, please log into your router and change the channel in your Wireless Settings.  Please try changing the channel to 11 or 6.  Changing the channel may eliminate any interference.
Interference can come from Bluetooth devices, cordless phones, microwave ovens and other nearby wireless networks if they are on overlapping channels.  Please refer to your routers' documentation for assistance in changing the wireless channel.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
powered by Lithium
