12-22-2015 03:02 PM - edited 12-22-2015 04:22 PM
MF Tool Box 4.9 cannot connect to MF6160dw
MF Tool Box 4.9 was connecting fine to MF6160dw to use the scanning functions under Windows 10.
I just upgraded to the latest version of Windows 10
Windows 10 Pro Version 1511 OS Build 10586.36
Now MF Tool Box 4.9 Cnnot communicate with the scanner.
Though the settings find the scanner
and the Canon MF Network Scan Utility finds the scanner
And Windows Fax and Scan finds the scanner and can scan using it
Also the Printer/Scanner is on and scanner set to remote
So does MF6100 Tool Box 4.9 not work with the latest Windows10 build?
I can however print on the MF6160dw with no problems
