Reply
Highlighted
New Contributor
Connecting Pixma MX452 To Wifi
When I initially set up my new MX452, I connected it locally to my iMac with USB. It works fine that way, but now I want to switch to Wifi, and I can't seem to make it work. I have connected the MX452 to our Wifi network using the instructions for WPS, and it shows as connected - the printer has been assigned an IP address. But I can't connect to it using Wifi from my iMac. When the printer is plugged in via USB, I see it with a green light and "Idle" in "Print & Scan". But when unplugged from USB, it shows a red light and "Offline". If I try to add it as a new printer, it isn't found. Using OSX 10.8.5  . Thanks for any help. And just to clarify, our Wifi network is working just fine - any other Wifi device in the same vicinity connects to our network with no problems.
Highlighted
New Contributor
Re: Connecting Pixma MX452 To Wifi
Did you ever find anybody to help you
powered by Lithium
