PIXMA TS3100 Series - How to reconnect printer after router change
tapmaxalf
Hello, i installed and set up a TS3100 a few weeks back. Last week I changed the wifi router in my home and unsure how to reconnect to the printer now. Haven't had any luck searching through the forums for an answer to this so wondered if someone knew?
Thanks
Start here.
Download this, save to your desktop.
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDEwMDAwODc1ODAy&cmp=ABR&lang=EN
Now review the instructions for wirless set up here:
Support | TS Series - Inkjet | PIXMA TS3120 (TS3100 Series) | Canon USA
Next:
Remove the printer from your system. Uninstall any Canon priter drivers.  Restart
Run the set up file you downloaded above and configure the printer to connect to the new router (SSID and password)
~CarePaks Are Worth It
5 REPLIES 5
Start here.
Next:
Hero! worked. thank you
Glad it helped!
Cheers
hi again.
i'm having the same issue, two years later. i've tried other posted solutions (trying to use my phone connect via the canon network, but even that doesn't work). can you please help? thank you thank you. (maybe you have an updated link for this solution?)
thank you so much
Not sure where you are located.  Some models have specific downloads based on region.
The link below should work for the TS3100 Series and most variants.  The Wi-Fi Connection Assistant may be particularly useful.
Thanks for the kind words in your PM.
Canon Support for PIXMA TS3122 | Canon U.S.A., Inc.
