02-26-2021 10:57 PM
I get to the point where my computer finds the printer on the network but then it says "connection failed. une another method for setup. follow the on-screen instructions." What could be causing this to happen.
02-27-2021 10:25 AM - edited 02-27-2021 10:26 AM
We know you have a MG3620..
But we don't know what operating system you have or how the printer is connected and to what?
So my advice might not be 100% appicable to your situation or environment?
Disable IPv6
Check your Firewall settings
If you are using any 3rd party antivirus, this might cause a communication issue with the device during install
Are you using the correct installer package for your operating system
Test with another USB cable
~CarePaks Are Worth It
Disable IPv6
02-27-2021 10:22 PM
Can you tell me what the issue was?
01-05-2024 01:42 PM
I disabled IPv6, disabled Norton Firewall and connection still fails. Shouldn’t I be required to enter the WiFi password? That does not occur
03-04-2024 05:56 PM
How does one disable a PIXMA (TS3320) printer's IPv6 if nothing will connect to it? [Canon PRINT on my phone says the printer is offline, win-ts3300-1_5-n_mcd.exe (which calls itself "Master Setup" in Windows 10 Task Manager) reports "connection failed", etc., etc.] Can I disable IPv6 at the printer console?
02-28-2021 12:28 AM
01-05-2024 01:23 PM
I disabled Norton Firewall and connection failed again. Using Windows 10. Will see what happens using USB
