Reply
Highlighted
Re: Canon PIXMA MG3620 Won't connect Wirelessly to PC
Priyanka,
Make sure that your computer is connected to the same SSID as the printer.  If the error persists, try uninstalling and reinstalling the drivers to see if this will allow the unit to communicate again.
If the issue persists, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
Highlighted
New Contributor
I have an MG3600 series and I am having the same problem. I have followed all the steps with both using the color button and black button to try and setup the wireless. When I do the network test it says Infastructure Enable, Connection Inacvtive, SSID BJNPSETUP, Channel Blank, Encryptyion none, WEP Key Length Inactive, Authentication open. PLease help this is super annoying I have already wasted 2 hours trying to set this up in 10 different ways.
Highlighted
New Contributor
I cannot get my new canon mg3620 to connect to my laptop.  I have printed out the network configuration page as was recommended in a previous question and this is what I have.
Connection - inactive
SSID - BJNPSETUP     (I do not recognize this)
IP address is blank
Highlighted
Hi hoodsiecup,
The BJNPSETUP SSID indicates that the printer is ready to be connected to a wireless network, but has not done so yet.  The PIXMA MG3620 can be connected to a network a few different ways, so if one method is unsuccessful, another can be used.  I have included instructions for those methods HERE.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
Highlighted
Occasional Contributor
Discription:
When I just got my printer, it was able to connected to my devices smoothly. But after I moved it to a new spot in the same room, it loses the connection with all my devices. I've attempted countless times try to reconnect it with my tablet, PC, and iPhone but never succeed.
The problem:
The printer can be found by the software "Canon IJ Online Master Setup" by "press and hold signal button, then press black/colour button, then press signal button". It has the serial number and MAC address, but no IP address. If I click next step, it will say "the connection is complete" and the power button and signla button start to blinking at the same time.
I click "nect step" the installation suddenly stopped, the software start to searching for the printer on network. At this point, the alarm lamp lighted up without any blink, the signal button start to blinking twice a time.
    Network Configuration Page:
Product Information
    Product name           MG3600 series (my machine is MG3620)
    ROM Version            2.050
    Serial Number          (Classified)
Wireless LAN                Enable
    MAC Address           (Classified)
    WPS PIN CODE       (Classified)
    Infrastructure             Enable
        Connection            Inactive
        SSID                      (my home WIFI name)
        Channel                 (blank)
        Encryption              none
        Authentication        auto
        Signal Strength      0% (before was 67% at the same spot)
        TCP/IPv4               Enable
        IP Address             (blank)
        Subnet Mask          (blank)
        Default Gateway    (blank)
        TCP/IPv6                Enable
        IP Address             (blank)
        Subnet Prefix Length    (blank)
        IPsec                      Inactive
        Security Protocol    (blank)
Access Point Mode         Disable
    Connection                 (blank)
    SSID                           (blank)
    Password                    (blank)
    Channel                      (blank)
    Encryption                   (blank)
    Authentication             (blank)
    TCP/IPv4                     (blank)
    IP Address                   (blank)
    Subnet Mask               (blank)
    TCP/IPv6                     (blank)
    IP Address             (blank)
    IPsec                      Inactive
Highlighted
Honored Contributor
[ Edited ]
If you go back to the old spot does it work?
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
Highlighted
I am positive it is not the main issue in my situation
Highlighted
Honored Contributor
So you are saying that the signal is now 0% and it doesn’t matter what position?
Sounds like Ike something happened to your WiFi router?
Highlighted
It had 67% Signal strength on the same spot before
Highlighted
and all my other devices are connected to this WIFI without issue
powered by Lithium
