Reply
New Contributor
Can’t connect Imagegraf Pro-1000 to new Netgear OrbiAX4200 WiFi 6 router
I have downloaded the updated firmware for the printer and I cannot get the printer to connect properly with the network on a consistent basis.  I had this printer operational for a couple of years with no problem.  My workaround is to connect it directly with a cable which is a real pain.  I called Netgear and after spending 2 hours waiting for someone who knew what was the problem I was told that I should contact Canon and see whether they had a new driver for the new WIFI 6 technology.  Anyone else have such issues and who has a fix?  I'm on a Mac, Catalina, latest update.
Esteemed Contributor
Re: Can’t connect Imagegraf Pro-1000 to new Netgear OrbiAX4200 WiFi 6 router
[ Edited ]
Have a fair amount of experience with Netgear.  Am also familiar with Canon.
A newer driver is not going to solve the problem.  Your Prograf is not Wi-Fi6 (AX) capable, so it will never take advantage of this technology.
The Orbi's AX chipset is backwards compatible and will allow devices based on older wi-fi standards to connect without needing anything special.  Although the Orbi is Triband, one of the 5G broadcasts is used for backhaul
Normally I would suggest that you disable SMART connect.  The printer has a 2.4Ghz (N) radio and cannot conect to a 5G broadcast.  Unfortunately, it looks like Netgear has done away with this option on newer Orbi's.  Ensure you are using WPA2 for security.
Final thoughts.  You'll get the best performance from your Pro-graf connecting it via an ethernet cable.  You can connect it to the router or sattelite.  This will allow all devices (wired or wireless) connecting to your network access to the printer.  Why this connection method is preferred.  Wireless performance when you are transfering large images is not ideal.  So best performance will be achieved using ethernet (all devices) where possible, but at the very least the printer.
Prograf 100 Full driver package v1.4
Orbi AX4200 RBK750 series Manual
~6D2(v1.1.0) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 2080 FTW3 Ultra ~Pixma Pro-100 ~ImageClass MF644Cdw ~LBP622dw
New Contributor
O.k. thanks.  Makes sense.
powered by Lithium
