01-06-2020 09:07 PM
01-08-2020 02:53 PM - edited 01-08-2020 02:54 PM
Hi Jgvillela,
Please follow these steps:
1. Please press the gear icon
at the bottom of e display of your PIXMA TS6220.
2. Select Device settings.
3. Select LAN settings.
4. Select Wi-Fi.
5. Select the Settings button in the lower right corner.
6. Select Wi-Fi setup.
7. Select Manual connect.
Does your wireless network appear in the list?
If so, please select it and then enter your wireless password.
Once connected, on your iPhone, please select Settings and then Wi-Fi. Make sure that the wireless network that you selected on the printer is the same network that your iPhone is connected to. If not, please select the same network.
When both are done, please attempt to print from your iPhone.
