04-01-2015 11:12 PM
What thread size is the mounting bracket socket on the 600EX-RT? The manual shows the SB-E2 bracket but apparently it is not available.
04-02-2015 04:48 PM - edited 04-03-2015 01:15 PM
You can sometimes get bracket via eBay. It comes with off-camera cable. It's pricey.
04-03-2015 12:01 PM
It's not 1/4"-20 (20 means 20 threads per inch (TPI)). It's finer than that.... it looks like it may be 1/4" 28 (which is another fairly common TPI used with 1/4" bolt diameters.) 1/4"-20 is the standard "coarse" thread and 1/4"-28 is the standard "fine" thread when dealing with 1/4" diamter threaded bolts.
I can't verify that though as I don't have a 1/4"-28 bolt to test for fit (but I am looking at my 600EX-RT now and can clearly see that it has finer threads.)
There is, however, a 1/4"-20 mounting hole on the mounting foot that comes with the flash. That's the plastic foot that has a "cold shoe" to attach the mount and allows it to stand on a table or floor. On the underside of that plastic foot, there is a 1/4"-20 mounting hole.
If you'd like to use the mounting hole on the lower left side of the flash body itself, then you may need to get a 1/4"-28 bolt and test it for fit.
04-03-2015 01:17 PM
The thread is metric M6 x 0.5
The SB-E2 is available on Ebay. The price may seem high but it includes an OC-E3 cord.
04-03-2015 04:01 PM
Thanks for your reply. I knew it was not 1/4-20. Your help is appreciated.
