Reply
New Contributor
Accepted Solution
Speedlight 600EX II-RT not charging
I just purchased this speedlight new at the end of December I have used it once. I went to use it tonight and it will not charge. The light just stays red. I put new batteries in just Incase, nothing. It does put off a test flash when I push the button. I have speedlight option enabled on my canon 5d Mark IV. I have looked through the entire manual and I can find nothing other than the solid red light means something about tempature but that’s not it because I didn’t even use it. Any suggestions? Thank you.
Esteemed Contributor
Re: Speedlight 600EX II-RT not charging
Call canon, they can walk you through some troubleshooting and have you send it in for repair if necessary.  If it is under waranty, don't bother with us.
Reputable Contributor
[ Edited ]
If your flash will fire a test flash, and takes photos normally, there is nothing wrong.
Check your user manual:   The flash-ready lamp will first turn green (ready for quick flash), then red (fully recycled or flash
ready)
With strong batteries and low power flash, you won’t see green.
Mike Sowsun
S110, SL1, 80D, 5D Mk III
New Contributor
Thank you! I’m obviously very new to speedlights. I knew the first time I used it that it was green. I got nervous when it was red all the time. I was just confused. Thanks for clearing that up for me.
Don't blame yourself. Every newbie is confused by the counterintuitive assignment of those lights. Of course one naturally assumes that the "all systems are ready" light would be green, not red. But it is what it is, and we all get used to it eventually.
Bob
powered by Lithium
