12-08-2012 12:30 AM
I am trying to link a Speedlite 580 EX II wirelessly with ST-E2 transmitter, and having some difficulties. Any advice out there?
12-08-2012 04:32 AM
What's exactly is the difficulty you're having? Any particular step/setting that is confusing? or problem that you're encountering?
12-08-2012 05:22 PM
There are only five possible causes of problems;
Most likely cause is the 580EX II can't see the pulses of light from the ST-E2. If you have the 580EX II in a softbox like the Apollo ones then it's almost sure not to see the signals from the ST-E2. If the 580EX II has it's head pointing towards the subject rotate the body of the flash so the red flashing bit on the front is aimed back at the ST-E2.
If these aren't the cause then you'll need to give a bit more to work on. Tell us some more about the settings you have on the 580EX II, and if you are using ratio mode on the ST-E2. Try pressing the camera's depth of field preview button to cause the flash to give a short burst of light - intended as a modelling light. If this works then you should be good to go.
Group C on the 580EX II can be the oddball since if the ST-E2 is set to fire everything ie not ratio, then it will trigger group C flashes, but if you then change to ratio control on the ST-E2 it will not trigger Group C flashes.
cheerio,
Brian
