Reply
Esteemed Contributor
Re: External flash
You have to have the internal flash on to communicate with the 430 flash. It uses pulses of light from the flash to send signals. I strongly suggest you download the full manual and go through the wireless flash section of the manual.
Occasional Contributor
Re: External flash
I havent tried anything with the 270 yet. I have the setting just like Mike said and couldn't get it to work
Reputable Contributor
Re: External flash
The 430EX RT-II has both radio and optical wireless capability. Because your camera can only use optical, make sure the flash in in optical slave mode.
The 270EX only has optical slave, so try it and see if it works
Mike Sowsun
S110, SL1, 80D, 5D Mk III
Re: External flash
Re: External flash
These are the settings I have on my camera and the flash. Maybe it might help out ? Am I doing something wrong??
Re: External flash
[ Edited ]
It looks like you have OPTICAL wireless enabled. It should work.
Just double check the channel and group to make sure it is all the same.
Review all the steps below to make sure you didn't miss anything:
Mike Sowsun
Re: External flash
I called a local camera shop and they said the flash on the camera needs to go off to trigger the speedlight. Is this true? I have the camera and speedlight on the same chanel and it won't go off. I just want the speedlight to go off without using the camera flash
Re: External flash
Yes, the camera's built-in flash must fire to trigger the slave in optical mode.
BUT.... The way you have it set, you will see the flash fire, but it is actually sending coded optical light signals just before the slave flash fires, and you should not see the light from the built-in flash in your photo.
Mike Sowsun
Re: External flash
Ok thanks
powered by Lithium
