09-11-2019 03:59 PM
09-12-2019 01:17 AM
Hello,
A 430 EX can be set up off camera and fired remotely, however you will need the pop up flash on your EOS 80D to control this. The 430 EX flash does not use the RT or radio trigger system to fire the flash, instead the flash on the EOS 80D will be the controller to let your 430 EX know when to fire.
For a detailed guide on this you can refrence the manual of the 430 EX Speedlite on page 23 which will show menu options and diagrams on how you should se the camera and flash up.
09-12-2019 10:21 PM
Thanks!
I thought my book was a bit brief!
