01-03-2014 11:04 PM
I assume I can use the old Battery Pack CP-E with an 600EX-RT. Is that correct?
01-03-2014 11:54 PM - edited 01-03-2014 11:58 PM
Yes, it will work just fine. All the Canon "Compact Battery Packs" put out the same 300 volts. It doesn't mater if they have 6 AA batteries or 8. The output volatge is the same.
