Reply
Highlighted
New Contributor
430 EX II Stuck at 90 degrees
My 430 EX II Stuck at 90 degrees pointing parralel to the lens. When I push the button to rotate it up to the ceiling it won't go.
If I don't push the button on the side it won't go at all. When I do push the button it will go a couple more degrees but returns to the lowest angle.
Thoughts?
Thanks
Highlighted
Esteemed Contributor
Re: 430 EX II Stuck at 90 degrees
[ Edited ]
 Are you saying the bounce lock release button isn't working?
Sounds like its broken or failed.  No magic.  If it doesn't release when pressed, the mechanism might have failed.  I have the same flash, except mine moves.
~6D2 ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 2080 FTW3 Ultra ~Pixma Pro-100
Highlighted
New Contributor
Thanks for the diagram. That is correct.
Now, is it worth sending it out for repair or is the cost close to replacing it?
Thanks for the help.
Highlighted
Honored Contributor
[ Edited ]
Keh Camera has some for slightly more than $100. Looks like Canon estimates $89 for repair.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair/repair?cm_sp=CSO-_-support/...
1D X Mark III, Rebel T5i, Many lenses, Pixma PRO-100, MX472, LR Classic
Highlighted
New Contributor
Hmmm.. For the difference in price maybe I will buy new. I assume that I can use my current 430 EX II as a slave?
powered by Lithium
