Reply
New Contributor
Re: problem with DPP after update to MacOS Mojave
Good Morning!!!
I Just tried to do the same and had no problems.
DPP 4.9.20
Mac OS 10.14.1
The first time asked a question about give permissions to DPP in Finder to make changes.
Greetings!
New Contributor
Just joined as I have discovered the SAME issue with my Canon 9000F. Canon tech support told me they are no longer supporting this scanner! Not happy.
However, by doing some serious googling, I have discovered an alternative to buying a new scanner (Canon doesn't even offer a flatbed which does photos, slides and negatives anymore -- something I need)!  While it costs a bit (US$99.95 after you trial it for the "professional" version needed for slides and negatives -- watermark appears on scans), try VUESCAN. You scan via their software, not the Canon driver.  I am now trialling it to see if it does what I need.  Not thrilled with the $100, but the alternative of buying a new scanner when this one works perfectly fine would be that much more.
VIP
I use Vuescan with a Minolta scanner. Driver ended with XP. Works fine now with W10. Haven't tried it with macOS.
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
New Contributor
Has anyone tried SilverFast 8.8? This seems to be another 3rd party company that will scan your photos and documents on several different scanners including the 9000F.  Trying their demo now also
New Contributor
Hi  Helene,
Reinstalling the system, this is not the solution where I'm looking for. I've the same problem, I cannot deleted images directly from the DPP, nor can I move the files to another map: the system is blinking for a shorttime  and the focus is moving from selected image ito the next image in the main window (or the system shows a Finder window).
Do you have other suggestions?
Regards,
KoosB
Occasional Contributor
Hi Koos,
I understand that is not the solution you are looking for. It wasn't the solution I was looking for either, but it was the only solution that worked for me. Maybe somebody else has a better solution.
Regards,
Helene
New Contributor
I have the same problen called Canon they were no help - I can Delete on my desktop but NOT my MacbookPro which is my shooting computer. This really sucks - as a life long Canon owner and a Pro this is no way to treat us. When a client is looking at the images on set it would be nice to delete the 1st serveral files.  CANON Help how about it . We're not making this up .
Peter Olson Philadelphia.
New Contributor
The answer is:
System Preferences / privacy / Full disc access
Click on the padlock and then add in DPP4 using the finder.
(This might not be enirely necessary but I think it helps!)
Then:
System Preferences / privacy / Automation
You'll see DPP4 and a tick box underneath 'Finder'
Tick the box and then click the padlock to save changes.
This should now work.
Thanks to Canon tech support for getting most of the way there!
New Contributor
A few weeks ago in some trial and error sessions, I've found this solution too, but I did not find the time yet to exactly write down what I have changed. But I had adapted the system like you proposed.
Problem solved.
Best regards,
Koos Blokland
I encountered a similar problem. It seems that DPP4 doesn'tnecessarily prompt the user for the appropriate user permission in Mojave. Do this manually, access System Preferences -> Security & Privacy -> Privacy Tab -> Automation to ensure that the Finder box is checked beneath DPP4 (see screenshot below).
- David
Security & Privacy/Privacy Tab/Automation Settings
powered by Lithium
