12-21-2014 04:26 PM - edited 12-21-2014 06:42 PM
I just installed EOS Utility 2 on my macbook air and am pairing it with my T3i camera, when I go into Liveview through my pc, it keeps shutting off after 15 seconds or so.
Is there any way to keep this on?
I keep having to click 'Depth of Field' preview on and off, and actually it shows live when it's clicked off (blue), but again, it shuts off too quickly.
Thanks!!
12-29-2014 06:23 AM
Hi traveler582!
Thanks for posting.
After about 30 seconds of non-operation, the camera will turn itself off to conserve battery power. You can then wake it up by pressing a button, typically the shutter button halfway pressed works the best. I recommend that you change the Auto Power Off setting so this does not happen so often, or at all.
12-29-2014 06:23 AM
Hi traveler582!
Thanks for posting.
01-02-2015 07:14 PM
How about I say, your response, in addition to Canon's rsponse, which was for me to install:
"EOS Digital Solution Disk Software 29.0A".
made it possible to now work beautifully!!
Thanks
