06-16-2021 05:05 PM
Hi all,
So, I want to save edited files in DPP4 and resize them when saving, but...
If I want the max height of a portrait image to be 1000px and the max width of a landscape image to be 1000px do I have to save them seperately?
I guess, what i am looking for is a way to resize by "percentage". Is that even possible?
06-17-2021 06:29 AM
Welcome to the forum.
Check the "Maintain aspect ratio" box and then insert 1000 in each size box.
06-18-2021 05:37 AM
06-18-2021 06:40 AM
@Real_Badman wrote:
Ok, thank you, I thought that would result in all saved images being square.
As long as you check "Maintain aspect ratio" you will get what you want.
06-17-2021 11:01 AM
@Real_Badman wrote:Hi all,
Follow John's advice just above. But if you want a final image that is 1000 x 1000, then you will need to change the aspect ratio of the image from the fault 3:2 to 1:1. This should crop off the sides of the images to make it square.
06-18-2021 05:41 AM
