Reply
Occasional Contributor
Accepted Solution
Raw images into image.canon
Why can't I send raw images from my EOS 6D to image.canon? Is it normal? I can only send JPGs Smiley Sad
EOS 6D, EF 24-105 mm 1:4 L IS USM, EF 50mm 1:1,8 II, Speedlite 580 EX II
Esteemed Contributor
Re: Raw images into image.canon
The FAQ on the website says you can - are you sure the 6D is a Canon camera? 8^) - but image.canon has had a *lot* of teething pains. This could be one.
[ Edited ]
Yes, I'm sure. It's Canon camera. Moreover, EOS 6D is on the compatibility list.
Respected Contributor
[ Edited ]
Neither can I with my two Canon EOS 6D. Works with Canon EOS M5.
It is possible to transfer raw files from 6D to third-party apps.
I use firmware 1.1.6 for 6D.
DCS 3c, DCS 520, D30, D60, 1Ds, 300D, 30D, 1000D IR, 7D, 6D, 6D, M5
15-45/3.5-6.3 IS, 16-35/4 IS, 22/2, 24/1.4 II, 24-105/4 IS, 50/1.4, 50/1.2, 85/1.8, 85/1.4 IS, 100/2.8, 70-200/2.8 IS II, 300/2.8 IS
I know this, but I would like to work with only one application. I am still using EOS Utility 3.
With best regards
[ Edited ]
"April 23, 2020
Important announcement regarding cameras unable to send RAW images (CR2 format) to image.canon
We regretfully inform you that RAW images (CR2 format) cannot be directly sent from the following cameras to image.canon due to the fact that those cameras currently do not support the function to send RAW images (CR2 format) via the Internet.
We hereby apologize and correct the information on this site that described all models can send all image format to image.canon.
EOS 5D Mark IV / EOS 6D Mark II / EOS 6D / EOS 80D / EOS 70D / EOS 77D / EOS Rebel T7i / EOS Rebel T7 / EOS Rebel T6s / EOS Rebel T6i / EOS Rebel T6 / EOS Rebel SL2 / EOS 200D / EOS 800D / EOS 750D / EOS 760D / EOS 1300D / EOS 1500D / EOS 2000D"
Thank you. I noticed this information yesterday.
I hope it will not be a firmware update because I want to use 1.1.6.
I hope too. I do not like to rummage in the hardware and especially in its firmware Smiley Very Happy
@Peter wrote:
"April 23, 2020
IEOS 5D Mark IV / EOS 6D Mark II / EOS 6D / EOS 80D / EOS 70D / EOS 77D / EOS Rebel T7i / EOS Rebel T7 / EOS Rebel T6s / EOS Rebel T6i / EOS Rebel T6 / EOS Rebel SL2 / EOS 200D / EOS 800D / EOS 750D / EOS 760D / EOS 1300D / EOS 1500D / EOS 2000D"
Isn't that pretty much every model DSLR?  So is there any model that does support RAW? It doesn't look like it.
powered by Lithium
