Reply
Highlighted
Occasional Contributor
Re: Playing With DPP and 2 Questions
You know, on second look Roger, yours may only be showing the folder as well and not the image name itself.
Highlighted
Respected Contributor
The image name shows up in the navigator pane at the bottom of the tool set in the lower right corner.   Here is a crop of the second screenshot when I had four files selected for the edit window.
If you hide the tools on the right, then you also lose the navigation pain with the file name in the bottom corner.
I don't find the extra bar at the top of the page with the Edit image, print, save choices to be useful and if you click the arrow above it will hide those slightly increasing your usable screen area.  Control left takes out of the edit window back to the image browsing mode.
EOS 1DX M3, 1DX M2, 1DX, 5DS R, 1D M2, EOS 650 (film), many lenses, XF400 video
Highlighted
Now THAT helps! I had the navigator at the bottom of the Edit panel. Movedto the top and suits my need. Thanks!
Highlighted
You are welcome!  DPP does a great job with RAW conversion and once you get used to it, you can work with it quickly.  It can't do everything PS can but I use it for a lot of images without further processing in PS.
One thing that slows it down even with a very fast machine is if you choose digital lens optimizer early in the process.  I suggest doing most of the edits and then run the optimizer near/at the end.  I am using a dual processor workstation with a lot of memory and a fast video card with a lot of CUDA cores and DLO still really slows the process.
Rodger
powered by Lithium
