06-28-2019 04:04 PM
Hi folks,
Have never used DPP but now with CR3 I am testing DPP and learning. Two questions please:
1. I'd like to double click a thumbnail or group of selected thumbnails and go to the Edit Window instead of the floating window. How can I set that?
2. I see nothing like the Post Crop Vignetting in LR which I use often. Am I missing that?
Thanks.
~Bob
06-28-2019 05:21 PM
No on both counts. The only customizing of DPP is in the Preferences section.
06-28-2019 05:41 PM
Thanks for the reply.
But unfortunate.
06-28-2019 05:55 PM
Is there any way to display the file name while editing? Not seeing that eother if I select several images to edit and move betwen images.
Thanks again.
06-28-2019 09:02 PM
If you select multiple images they show in the thumbnails and the selected image is highlighted. Does this do what you want?
06-28-2019 09:20 PM
Thanks, but no. Prefer to hide the thumbnails and make use of the screen real estate. But no indication what image I am on. Would be nice in the title bar or elsewhere.
06-29-2019 09:49 AM
It probably depends upon operating system and monitor/driver resolution but in my DPP setup the file name is visible in the Navigator pane in the lower right corner below the selected set of image tools. I agree it would be nice to have the file name displayed at the top as part of the directory (or even instead of when in edit mode).
Rodger
06-29-2019 11:25 AM
Thanks, but unless I am wrong you have only one image selected or the arrows would be live. Can you go to browse, select three or four, hit CTL-Right Arrow for Edit and see if that is still there? That is what would be useful for me so I can see which of the selected images I am working on without giving up all the real estate the film strip takes.
~Bob
06-29-2019 11:56 AM - edited 06-29-2019 11:58 AM
Bob,
That portion of the navigation window does remain with multiple images selected for editing, 4 selected in this case as indicated by the counter on the left bottom of the DPP screen.
Rodger
06-29-2019 12:14 PM
Thanks again. Exactly what I would like, but does not do that for me.
