Reply
Highlighted
New Contributor
Accepted Solution
Initial Setup
I installed the web cam utility.  It looks like it installed ok. Connected my 7d mark ii.  Don't see where the application is to start it.  Is there any sort of user guide for the application?
Highlighted
Esteemed Contributor
Re: Initial Setup
You don't "start it", it allows your computer to be used as a webcam for other apps like Zoom.
Highlighted
New Contributor
Re: Initial Setup
I had initially thought it was an application, since it calls itself a utility.  But apparently it is essentailly drivers.  In any case I installed OBS.  I was able to select my camera for video but not for audio.  Is that normal so they encourage the use of an actual micophone or is something not detected correcly there as well?
Highlighted
Moderator
Re: Initial Setup
Hi, kellydj! EOS Webcam Utility simply provides a live picture. For sound, you'll need to connect a separate microphone or audio source to your computer.
Hope this helps!
Highlighted
New Contributor
Re: Initial Setup
I guess my only follow up question would be why do tutorials only mention using the USB output instead of the HDMI?  Is that because most people don't have a capture card that would suppor it.  Thanks so much for helping getting Canon cameras more useful with utilities like this.
powered by Lithium
