09-11-2015 08:08 AM
I did invoke EOS utility 2 and it made no diference.
The answer to my problem was to prevent my AVG antivirus from blocking the software. AVG did allow all my other Canon software to operate successfully without any problems.
Regards
Dennis
05-30-2016 10:12 PM
Microsoft surreptitiously upgraded my Windows 7 to 10, which I did not want. I ended up reinstalled Windows 7. Canon's EOS utility 2.14.20, however, crashed on launching. What I finally was able to get it to work was to install 2.14.01, which was supposed to be for Windows XP. Hope this may help someone.
10-06-2016 07:14 AM
same problem still exists:
my 5dsr is recognized normally as 5dsr on my usb2 ports. works fine with eos utility.
on the same machine on the usb 3 ports it is only recognized as MTP portable device by windows and does'nt work with eos utility.
tried all the suggested workarounds and fixes. no succes.
please fix the driver! otherwise the usb 3 plug is useless for me.
10-28-2016 12:04 PM
Having sincere trouble setting up Eos software with my canon camera , the camera settings and shooting element is greyed out , can,t seem to find even after updating from the website how to connect this part of the software , any ideas camera buddies!
11-19-2016 06:31 AM
I've tried your "plan B" and doesn't works on my windows 8.1 !! help! Canon! I wan to work RAW archives!!!!
11-19-2016 06:47 AM
My Canon Utilities on my windows 8.1 can't found a dppdll.dll to work it, I've copied on its place and doesn't work, help please! I want to use raw archives!
11-19-2016 01:31 PM
Download a fresh archive and re-install.
11-19-2016 04:30 PM
@kvbarkley wrote:Download a fresh archive and re-install.
And when you do, remember this: If you're on a 64-bit Windows OS, install Version 3 of EOSU, even if you don't think your camera can use it. Installing Version 3 causes the installation of both versions (2 and 3). Then when you call up Version 3, it will determine whether your camera needs Version 2 and automatically call it up if it does. For some reason Canon describes this process in only the vaguest of terms, and users' misunderstanding of it is the basis for many of the problems reported regarding EOSU in the past two years or so.
12-03-2016 02:18 PM
I'm at a loss. About a month ago the Eos Utility stopped working. I was using version 2 since my update to windows 10. Since then, everytime I try to use it, I get the lovely message that a "problem" has occured and caused the utility to stop working. I have tried uninstalling it, reinstalling it, uninstalling windows updates, unplugging everything that was plugged into USB ports, installing utility 3, uinstalling utility 3. I'm at the point where I'm ready to throw my computer and camera out the window.
Now on that note, I really only use the utility for the downloading images and the organization aspect of it. So I guess my question is this....Is there a way to fix the utility so it actually works or does anyone have different program they use to download and organize their pictures?
03-05-2017 05:07 PM
