04-29-2020 04:02 PM
Downloaded and tried the installer today. When I run the installer, it says...
The installer was interrupted before EOS Webcam Utility Beta could be installed. You need to restart the installer to try again.
It does NOT say WHY it was interrupted. Restarting the installer produces exactly same results.
Computer is Win10/64 1903. Everything else works.
Anyone know what might cause this?
04-29-2020 06:50 PM - edited 04-29-2020 06:50 PM
No, since I have the same basic configuration and had no problem installing.
Did you try restarting the computer to see if you can clear a conflict?
04-30-2020 12:54 AM
Hi there,
Yes, restarting the PC may help clear any conflicts as stated above and that would be a great place to start. It would also be best to verify that no other programs are running and checking any antivirus software you may have, including Windows Defender, to make sure they have not applied any restrictions to the installer program. I also suggest moving the downloaded installer file from your Downloads folder directly onto your desktop just in case the Downloads folder has any restrictions applied to it specifically.
