05-26-2021 06:14 PM
I have not used the EOS Utility for remote shooting for a while now. I was was sure that the camera both recorded the images to the local camera memory cards and to the remote connected computer HD simultaneously. That is not happening now and I cannot find any setting to change it. It is only recording to the remote computer with both my EOS R5 and EOS 5D Mark IV. Did something change in the software of am I just not remembering things correctly? I downloaded the latest version 3.13.20.4
05-26-2021 09:06 PM - edited 05-26-2021 09:07 PM
Like you, I haven't used it for a year or so, but there used to be an option where you could select computer, card, or both. I just put together some old screen grabs from 2019. Maybe it's still this way... Just not sure.
07-13-2021 12:35 AM
I wasn't argueing, but agreeing with you that they run in conjuction. My gripe is with the program (DPP) and how it bogged down my system when testing it for remote shooting. DPP runs great on it's own as does the EOS Utility, but together they slowed everything down. Not sure why, it just does. Anyway, I've just always used the EOS Utility or Helicon Remote to shoot, save on the camera, then edit like any other session in DPP.
Newton
07-13-2021 07:21 AM
DPP has a button to start up Remote Shooting. The DPP manual clearly states that remote shooting requires that EOSU be installed. No EOSU no remote shooting.
EOSU allows a software other than DPP to be linked for viewing the remote shot images (or if no software is linked images won't be viewed but simply recorded). No DPP and remote shooting still possible. Seems like EOSU is the remote shooting controller.
07-13-2021 04:20 PM - edited 07-13-2021 04:42 PM
@jrhoffman75 wrote:DPP has a button to start up Remote Shooting. The DPP manual clearly states that remote shooting requires that EOSU be installed. No EOSU no remote shooting.
Great info, John. I've only searched the DPP manual for stuff I was interested in, so that one got by me. But, it makes common sense. Also, it is good to know that the EOSU will link you up to other editors, although that is not my workflow when shooting remotely as I record to my cameras SD card, then d/l via built in reader, and edit. I could see remote shooting from a program, like DPP, being useful for a portrait photographer, but I'm sure there are better programs out there for that. I shoot with two computers and cameras to get different perspectives, Helicon Remote on one and EOSU on the other.
I use DPP as my primary Raw editor, it's simple to use and has the fetures that I need. I use a "light touch" and just don't require more than a bit of sharpening, saturation adjustment, and sometimes noise reduction and lens correction. It just fills my needs for the type of photography that I do. So, I've seen the remote button, but it doesn't stay there long because once my images are loaded, it goes away. I tried it years ago, but don't recall why. I tested "remote shooting" from DPP yesterday simply because it was brought up and I posted that screen grab. DPP would hang (DPP is not responding message) after every shot. I assumed it was because it was downloading the file. It would evenually come back to life, but using DPP as the launcher isn't acceptable for shooting bird action, LOL.
Newton
07-13-2021 04:44 PM - edited 07-13-2021 05:04 PM
Hi Newton. The times that I have been tethered I used FastRawViewer as the linked software since I was only interested in verifying a good image. Everyone's workflow is different, but I never found a value in going to DPP while tethered since I wasn't going to be editing while tethered.
I did try using no linked software (and just get the Quick View screen) but I didn't see a significant benefit and got a larger (full screen) image with FRV.
DPP gets a bad rap from some folks, but I have found it to be quite good. Even though I do have and use Lightroom I frequently use DPP for initial RAW processing. Fine Detail PictureStyle coupled with DLO (and no other DPP processing) exported as a TIFF to Lightroom gives a good starting file.
You can see all sorts of reviews where "Lightroom is best", or "Capture 1 is best" or "DxO is best". I've tried trials and my conclusion, for what it's worth, is 1. they are all good, and 2. "X is best" should be interpreted as "I like X best as a starting point for my editing ".
05-27-2021 09:03 AM
07-11-2021 03:00 PM
Thanks! EOS version 3.13 (The current version, I believe) works exactly like you have so clearly described.
07-12-2021 04:31 PM
07-12-2021 04:39 PM
@jrhoffman75 wrote:
"I have found that Canon software is actually very good, but often the capabilities are not apparent because their manuals tend to not be so good, and their indexing approach is horrible."
Exactly! And sometimes they note the date/firmware version in the header of the PDF manual, sometimes not. But still, a logical "Key word" search comes up empty in the PDF and you have to start using your imagination. I know that sounds weird, but that is what I have to do.
Newton
