11-17-2020 11:28 AM
I will like to know if anyone have the full version of Big Sur OS and EOS Webcam Utility full version working together. If theres any bug or trouble using both together. Thank you
11-23-2020 05:11 AM - edited 11-23-2020 05:12 AM
Yes, I got it up & running on my MacBook Pro 13" 2017 with Big Sur. Just make sure, that the EOS Utility doesn't run at the same time.
11-24-2020 03:29 AM
In my case it didn't work. I cannot select the webcam utility in any program such as Zoom etc.
11-24-2020 03:37 AM
What do you mean by not running at the same time when Big Sur full version is the operation system. So it's Big Sur that runs the utility. Please clarify your point. Thank you
11-24-2020 03:39 AM
11-24-2020 04:04 AM
The regular EOS Software to transfer picture works fine (and yes, I turn that one off when I try using the Webcam Utiltiy) so I suppose it can't be the USB cable. But thanks for the input!
11-24-2020 04:06 AM
It means that I installed it when Big Sur is the operating system and it didn't work. The installation process itself seemed to work fine but I cannot select the Webcam Utility in any software.
11-24-2020 06:38 AM
Make sure to not run the EOS Utility at the same time with the Webcam Utility as the webcam will not be available then.
11-24-2020 09:28 AM
@PDS wrote:It means that I installed it when Big Sur is the operating system and it didn't work. The installation process itself seemed to work fine but I cannot select the Webcam Utility in any software.
Which camera are you trying to use?
Under Windows, there is an EOS Launcher Serivce, which detects the camera when you power it up and launches the appropriate version of the regular EOS Utlity for the camera that it detects.
You have to do one more step under Windows to make the WebCam work. You must disable the EOS Launcher Utility Service.
11-24-2020 09:33 AM
Canon EOS 5D IV
