Reply
New Contributor
Accepted Solution
EOS Webcam Utility Beta not installing correctly not creating shortcuts & not launching no .exe file
I installed using EOS-Webcam-Utility-Beta file for the 80D
In the folder C:\Program Files (x86)\Canon\EOS Webcam Utility Beta I only see these files
EDSDK.dll
EdsImage.dll
EOS Webcam Utility Software EULA.rtf
eos-webcam-utility-beta-x86.ax
<DIR> x64
and inside the x64 folder there is
EDSDK.dll
EdsImage.dll
eos-webcam-utility-beta-x64.ax
Not finding a way to actually launch the program and can't find an exe file anywhere. I've installed the 80D download on two Windows10 machines and so far still the same issue
Please help me just get it installed properly I guess. It goes through installation process normally without errors and after restart, nothing happens.
Re: EOS Webcam Utility Beta not installing correctly not creating shortcuts & not launching no .
Hi there,
The EOS Webcam Utility Beta does not function as an independant program, you can think of it more like a plugin. Once you have run through the installation of the Utility, you will want to set your EOS 80D to movie mode and then connect it to your PC via USB. Then you will open your webconferencing software and the EOS Webcam Utility Beta should populate as an option when selecting which webcam you would like to use.
New Contributor
Thanks for the reply.
I tried it on another PC as my laptop wasn't showing that and wasn't connecting if so. Now if worked so thank you.
The thing is that I've seen videos that show software of Webcam utility and EOS utility as well.
powered by Lithium
