EOS Utility 3 hangs on MACOS 11.0
jwestveer
The EOS utility 3 program hangs on macos 11.0 and does not find attached EOS camera.
Is there a beta EOS utility?
7 REPLIES 7
Waddizzle
Which camera are we talking about?  What OS are you using?  MAC OS 11 has not been officially released, yet.
Thanks for your quick response.
Companys often have to choose between mediocrity and excellence.
Date/Time:        2020-06-25 08:12:41.055 -0700
End time:         2020-06-25 08:13:55.765 -0700
OS Version:       macOS 10.16 (Build 20A4299v)
Architecture:     x86_64h
Report Version:   31
Data Source:      Stackshots
Shared Cache:     F0D63F1C-7E99-3B73-878C-0451D7DD560C slid base address 0x7fff2530d000, slide 0x530d000
Command:          EOS Utility 3
Path:             /Applications/Canon Utilities/*/EOS Utility 3.app/Contents/MacOS/EOS Utility 3
Identifier:       com.canon.EOS-Utility-3
Version:          3.12.10 (3.12.10.8)
Parent:           launchd [1]
PID:              7090
Time Since Fork:  75s
Event:            hang
Duration:         74.71s
Duration Sampled: 1.10s (process was unresponsive for 74 seconds before sampling)
Steps:            11 (100ms sampling interval)
Hardware model:   MacBookPro14,2
Active cpus:      4
Time Awake Since Boot: 163590s
Fan speed:        1248 rpm
Timeline format: stacks are sorted chronologically
Use -i and -heavy to re-report with count sorting
Heaviest stack for the main thread of the target process:
  11  start + 1 (libdyld.dylib + 89201) [0x7fff6b50bc71]
  11  main + 1048 (EOS Utility 3 + 52523) [0x108846d2b]
  11  NSApplicationMain + 790 (AppKit + 14936) [0x7fff28760a58]
  11  -[NSApplication run] + 586 (AppKit + 195403) [0x7fff2878cb4b]
  11  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1352 (AppKit + 251481) [0x7fff2879a659]
  11  _DPSNextEvent + 1602 (AppKit + 258304) [0x7fff2879c100]
  11  AEProcessAppleEvent + 54 (HIToolbox + 282047) [0x7fff2a257dbf]
  11  aeProcessAppleEvent + 452 (AE + 18060) [0x7fff2cf5f68c]
  11  ??? (AE + 46976) [0x7fff2cf66780]
  11  ??? (AE + 49253) [0x7fff2cf67065]
  11  _NSAppleEventManagerGenericHandler + 80 (Foundation + 215646) [0x7fff2e1b8a5e]
  11  -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 308 (Foundation + 216046) [0x7fff2e1b8bee]
  11  -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 665 (AppKit + 281264) [0x7fff287a1ab0]
  11  -[NSApplication(NSAppleEventHandling) _handleAEOpenEvent:] + 541 (AppKit + 282204) [0x7fff287a1e5c]
  11  -[NSApplication _sendFinishLaunchingNotification] + 208 (AppKit + 293987) [0x7fff287a4c63]
  11  -[NSApplication _postDidFinishNotification] + 312 (AppKit + 294682) [0x7fff287a4f1a]
  11  -[NSNotificationCenter postNotificationName:object:userInfo:] + 59 (Foundation + 38402) [0x7fff2e18d602]
  11  _CFXNotificationPost + 723 (CoreFoundation + 290526) [0x7fff2b826ede]
  11  _CFXRegistrationPost + 454 (CoreFoundation + 1119695) [0x7fff2b8f15cf]
  11  ___CFXRegistrationPost_block_invoke + 49 (CoreFoundation + 1119835) [0x7fff2b8f165b]
  11  __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 484044) [0x7fff2b8562cc]
  11  -[AppDelegate applicationDidFinishLaunching:] + 921 (EOS Utility 3 + 49444) [0x108846124]
  11  -[AppDelegate initCameraCache:] + 193 (EOS Utility 3 + 32979) [0x1088420d3]
  11  +[CameraCache initializeCache:selectDevice:selectFunction:] + 185 (EOS Utility 3 + 1341743) [0x10898192f]
  11  -[CameraCache(CacheController) getConnectedCamera] + 1955 (EOS Utility 3 + 1352438) [0x1089842f6]
  11  -[CameraCache(CacheController) setupComponent] + 325 (EOS Utility 3 + 1357663) [0x10898575f]
  11  -[CameraCache(CacheController) openSession] + 228 (EOS Utility 3 + 1348228) [0x108983284]
  11  +[UEDSDK openSession:error:] + 25 (EOS Utility 3 + 1537275) [0x1089b14fb]
  11  EdsOpenSession + 56 (EDSDK + 46716) [0x108d0e67c]
  11  CEdsCamera::OpenSession(int) + 66 (EDSDK + 118628) [0x108d1ff64]
  11  CPtpCamera::OpenSessionSelf() + 207 (EDSDK + 185437) [0x108d3045d]
  9   CIccMan::OpenRequest(void*) + 324 (EDSDK + 345296) [0x108d574d0]
  9   -[NSAutoreleasePool release] + 129 (Foundation + 125357) [0x7fff2e1a29ad]
  9   _CFAutoreleasePoolPop + 22 (CoreFoundation + 267608) [0x7fff2b821558]
  9   objc_autoreleasePoolPop + 161 (libobjc.A.dylib + 35410) [0x7fff6a2cea52]
  3   objc_release + 82 (libobjc.A.dylib + 33602) [0x7fff6a2ce342]
Process:          EOS Utility 3 [7090]
UUID:             A6349447-0047-319D-9A79-336D941BE0E9
App Version:      3.12.10
Build Version:    3.12.10.8
Parent:           launchd [1]
UID:              501
Footprint:        10.56 MB
Num samples:      11 (1-11)
CPU Time:         0.985s (3.7G cycles, 3.7G instructions, 1.00c/i)
Note:             Unresponsive for 74 seconds before sampling
Note:             2 idle work queue threads omitted
  Thread 0xa4ff1    DispatchQueue "com.apple.main-thread"(1)    11 samples (1-11)    priority 46 (base 46)    cpu time 0.984s (3.7G cycles, 3.7G instructions, 1.00c/i)
  <thread QoS user interactive (requested user interactive), process unclamped, IO tier 0>
  11  start + 1 (libdyld.dylib + 89201) [0x7fff6b50bc71] 1-11
    11  main + 1048 (EOS Utility 3 + 52523) [0x108846d2b] 1-11
      11  NSApplicationMain + 790 (AppKit + 14936) [0x7fff28760a58] 1-11
        11  -[NSApplication run] + 586 (AppKit + 195403) [0x7fff2878cb4b] 1-11
          11  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1352 (AppKit + 251481) [0x7fff2879a659] 1-11
            11  _DPSNextEvent + 1602 (AppKit + 258304) [0x7fff2879c100] 1-11
              11  AEProcessAppleEvent + 54 (HIToolbox + 282047) [0x7fff2a257dbf] 1-11
                11  aeProcessAppleEvent + 452 (AE + 18060) [0x7fff2cf5f68c] 1-11
                  11  ??? (AE + 46976) [0x7fff2cf66780] 1-11
                    11  ??? (AE + 49253) [0x7fff2cf67065] 1-11
                      11  _NSAppleEventManagerGenericHandler + 80 (Foundation + 215646) [0x7fff2e1b8a5e] 1-11
                        11  -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 308 (Foundation + 216046) [0x7fff2e1b8bee] 1-11
                          11  -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 665 (AppKit + 281264) [0x7fff287a1ab0] 1-11
                            11  -[NSApplication(NSAppleEventHandling) _handleAEOpenEvent:] + 541 (AppKit + 282204) [0x7fff287a1e5c] 1-11
                              11  -[NSApplication _sendFinishLaunchingNotification] + 208 (AppKit + 293987) [0x7fff287a4c63] 1-11
                                11  -[NSApplication _postDidFinishNotification] + 312 (AppKit + 294682) [0x7fff287a4f1a] 1-11
                                  11  -[NSNotificationCenter postNotificationName:object:userInfo:] + 59 (Foundation + 38402) [0x7fff2e18d602] 1-11
                                    11  _CFXNotificationPost + 723 (CoreFoundation + 290526) [0x7fff2b826ede] 1-11
                                      11  _CFXRegistrationPost + 454 (CoreFoundation + 1119695) [0x7fff2b8f15cf] 1-11
                                        11  ___CFXRegistrationPost_block_invoke + 49 (CoreFoundation + 1119835) [0x7fff2b8f165b] 1-11
                                          11  __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 484044) [0x7fff2b8562cc] 1-11
                                            11  -[AppDelegate applicationDidFinishLaunching:] + 921 (EOS Utility 3 + 49444) [0x108846124] 1-11
                                              11  -[AppDelegate initCameraCache:] + 193 (EOS Utility 3 + 32979) [0x1088420d3] 1-11
                                                11  +[CameraCache initializeCache:selectDevice:selectFunction:] + 185 (EOS Utility 3 + 1341743) [0x10898192f] 1-11
                                                  11  -[CameraCache(CacheController) getConnectedCamera] + 1955 (EOS Utility 3 + 1352438) [0x1089842f6] 1-11
                                                    11  -[CameraCache(CacheController) setupComponent] + 325 (EOS Utility 3 + 1357663) [0x10898575f] 1-11
                                                      11  -[CameraCache(CacheController) openSession] + 228 (EOS Utility 3 + 1348228) [0x108983284] 1-11
                                                        11  +[UEDSDK openSession:error:] + 25 (EOS Utility 3 + 1537275) [0x1089b14fb] 1-11
                                                          11  EdsOpenSession + 56 (EDSDK + 46716) [0x108d0e67c] 1-11
                                                            11  CEdsCamera::OpenSession(int) + 66 (EDSDK + 118628) [0x108d1ff64] 1-11
                                                              11  CPtpCamera::OpenSessionSelf() + 207 (EDSDK + 185437) [0x108d3045d] 1-11
        2   CIccMan::OpenRequest(void*) + 284 (EDSDK + 345256) [0x108d574a8] 1-2
        2   -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 128 (Foundation + 390125) [0x7fff2e1e33ed] 1-2
        2   _CFRunLoopFinished + 73 (CoreFoundation + 663564) [0x7fff2b88200c] 1-2
        2   __CFRunLoopCopyMode + 174 (CoreFoundation + 1343980) [0x7fff2b9281ec] 1-2
        2   CFSetGetValue + 88 (CoreFoundation + 286901) [0x7fff2b8260b5] 1-2
        2   CFBasicHashFindBucket + 1266 (CoreFoundation + 31806) [0x7fff2b7e7c3e] 1-2
        1   CFEqual + 64 (CoreFoundation + 38872) [0x7fff2b7e97d8] (running) 1
        1   __CFStringEqual + 130 (CoreFoundation + 1166673) [0x7fff2b8fcd51] (running) 2
        9   CIccMan::OpenRequest(void*) + 324 (EDSDK + 345296) [0x108d574d0] 3-11
        9   -[NSAutoreleasePool release] + 129 (Foundation + 125357) [0x7fff2e1a29ad] 3-11
        9   _CFAutoreleasePoolPop + 22 (CoreFoundation + 267608) [0x7fff2b821558] 3-11
        9   objc_autoreleasePoolPop + 161 (libobjc.A.dylib + 35410) [0x7fff6a2cea52] 3-11
        2   objc_release + 82 (libobjc.A.dylib + 33602) [0x7fff6a2ce342] (running) 3-4
        1   AutoreleasePoolPage::releaseUntil(objc_object**) + 159 (libobjc.A.dylib + 152969) [0x7fff6a2eb589] 5
        *1   call_continuation + 35 (kernel + 356915) [0xffffff8000263233] 5
        *1   ml_set_interrupts_enabled + 25 (kernel + 1943481) [0xffffff80003e67b9] (running) 5
        2   objc_release + 18 (libobjc.A.dylib + 33538) [0x7fff6a2ce302] (running) 6-7
        1   objc_release + 35 (libobjc.A.dylib + 33555) [0x7fff6a2ce313] (running) 8
        1   objc_release + 82 (libobjc.A.dylib + 33602) [0x7fff6a2ce342] (running) 9
        1   objc_release + 118 (libobjc.A.dylib + 33638) [0x7fff6a2ce366] (running) 10
        1   objc_release + 35 (libobjc.A.dylib + 33555) [0x7fff6a2ce313] (running) 11
  Binary Images:
           0x10883a000 -        0x108b5cfff  com.canon.EOS-Utility-3 3.12.10 (3.12.10.8) <A6349447-0047-319D-9A79-336D941BE0E9>  /Applications/Canon Utilities/*/EOS Utility 3.app/Contents/MacOS/EOS Utility 3
           0x108d03000 -        0x108da4fff  com.canon.edsdk 3.12.10.1 (3.12.10.1)       <DA066080-DF2C-3009-AEF5-734F810C45A2>  /Applications/Canon Utilities/*/EOS Utility 3.app/Contents/Frameworks/EDSDK.framework/Versions/A/EDSDK
        0x7fff2875d000 -     0x7fff295d7fff  com.apple.AppKit 6.9 (1997)                 <63730B25-E94C-3774-B05B-BEAF1851643D>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff2a213000 -     0x7fff2a512fff  com.apple.HIToolbox 2.1.1 (1037)            <A4BE414A-CFFC-3A51-8F48-3AF0491D4FBB>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff2b7e0000 -     0x7fff2bcc3fff  com.apple.CoreFoundation 6.9 (1740)         <ED9A6692-3C6E-3C34-84C8-E7BC1CF6D950>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff2cf5b000 -     0x7fff2cfcefff  com.apple.AE 913 (913)                      <CD59E262-0DF7-3298-A415-B38812745162>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
        0x7fff2e184000 -     0x7fff2e526fff  com.apple.Foundation 6.9 (1740)             <B1F110FE-81EE-380C-A03A-13F8DBB861E0>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff6a2c6000 -     0x7fff6a2fefff  libobjc.A.dylib (810)                       <BCCA39CD-97CE-326B-B17A-26B4EA35A1B6>  /usr/lib/libobjc.A.dylib
        0x7fff6b4f6000 -     0x7fff6b530fff  libdyld.dylib (823.2)                       <08672519-D6BD-372E-8362-9B6863C24AAB>  /usr/lib/system/libdyld.dylib
   *0xffffff800020c000 - 0xffffff8000c0bfff  kernel (7090.0.0.111.5)                     <8A20D5DC-6ED7-31BE-8E81-A5ADCBC358D7>  /System/Library/Kernels/kernel
Report Version:   31
Okay, now that we have established that you are not running MAC OS 11, aka Big Sur, I suggest you contact Canon Support with your issue.  They should be able to help you troubleshoot the issue.
Actually it is macOS 11 Big Sur beta.
"Today Apple released macOS Big Sur 11.0 -10.16 (20A4299v) Beta 1" - found via Google.
I have never seen a beta of Canon software posted. Maybe if you contact Canon directly they may have a beta test program you could join.
EOS Utility 3 hangs on MACOS 11 Beta 1 and 2.
jwestveer
MacOS Version 11.0 Beta (20A5323l)  (beta 3)  The EOS Utility 3 is working again !
Good. That bodes well for the actual release.
