EOS Utility 2 crashes on startup
rudibr
On my Windows 10 Pro computer, EOS Utility 2 crashes on startup, regardless of camera connected or not.
It has been working without an incident for the past half year, but now this malfunctioning.
I have tried uninstalling completely and installing "EOS Utility" from my CD and then upgrading to "EOS Utility 2", but the same happens, EOS Utility 2 crashes.
Any suggestions to what I could do?
Edit: I have a Canon 1000D (EOS Kiss F / EOS Rebel XS) so EOS Utility 3 is not an option.
From eventlog:
- System
- Provider
[ Name] EOS Utility
- EventID 0
[ Qualifiers] 0
Level 3
Task 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2017-09-19T07:20:25.672636100Z
EventRecordID 1590
Channel Application
Computer MaiaObs1
Security
- EventData
Configuration system failed to initialize at System.Configuration.ConfigurationManager.PrepareConfigSystem() at System.Configuration.ConfigurationManager.RefreshSection(String sectionName) at System.Configuration.ClientSettingsStore.ReadSettings(String sectionName, Boolean isUserScoped) at System.Configuration.LocalFileSettingsProvider.GetPropertyValues(SettingsContext context, SettingsPropertyCollection properties) at System.Configuration.SettingsBase.GetPropertiesFromProvider(SettingsProvider provider) at System.Configuration.SettingsBase.GetPropertyValueByName(String propertyName) at System.Configuration.SettingsBase.get_Item(String propertyName) at System.Configuration.ApplicationSettingsBase.GetPropertyValue(String propertyName) at System.Configuration.ApplicationSettingsBase.get_Item(String propertyName) at EOSUtility.AppSettings.get_FolderNameSeparator() at EOSUtility.RenamingService.RenamingFolder.updateFolderSeparator() at EOSUtility.RenamingService..ctor() at EOSUtility.RenameCountroller..ctor() at EOSUtility.MainMenu..ctor() at EOSUtility.Program.Main(String[] args)
21 REPLIES 21
rudibr
Darn it. I’ll avoid writing the model number here again. Obviously there’s no limit to how I can mess it up.
tcom
My was crashing with my USB 3.0 and WiFi conection but not with USB 2.0
installing  new Usb 3.0 card fix the problem with the cable
WiFi was crashing bucause i was using VPN. without VPN works with no problem
http://community.usa.canon.com/t5/Software/EOS-Utility-issue-Live-view-freeze/td-p/219136/page/2
