04-15-2019 04:11 AM
I’m running the SX60hs. I know the iApp won’t download RAW, but will it allow shooting RAW?
I've setup my SX60 with Custom Settings to C2 and checked that it’s shooting fine without the Connect iApp and it’s shooting RAW. I can even check in the iApp that there are RAW and JPEG on the card. So the iApp registers I’ve got previously, manually shot RAW. I know all the WiFi connections are working, oh yes. But, in all that’s sane, will somebody tell me that this iApp can or can’t Capture RAW?
Thank so much.
04-16-2019 02:40 AM - edited 04-16-2019 05:44 AM
This for my new SX60hs
Until a Canon Representative can confirm or deny, presently the Canon Connect iApp whilst being able to connect via WiFi to register that previously shot RAW footage, created WITHOUT the Canon Connect WiFi Live Capture, can be viewed as being RAW. However, using the Canon Connect for shooting will NOT capture RAW. In fact, the Canon Connect Capture Shooting Feature will ONLY capture JPEG and ONLY in PROGRAM Mode. It will ignore any ISO or WB Settings with ISO defaulted to 1000, and the WB defaulted to AutoWB.
I’ve experimented with using C2 and applied my own settings leaving the Camera on C2 whilst I fire-up the Canon Connect iApp and captured shots only to see that NONE of my settings had been actioned. The Canon iApp totally ignores my settings and again uses some “P” Setting of JPEG, AWB and ISO 1000.
Any Canon Representatives offering advice or an SX User who’s had a better experience than I, please chip in.
04-18-2019 04:05 PM
Hi Grazie,
Thank you for posting.
While your camera still shoots in RAW when using the Camera Connect App, because the app cannot read RAW images, it receives JPG images from your camera. The RAW images are stored on the memory card in your camera.
The RAW images, stored on your camera still contain all decision data, so your settings are retained in the RAW image files.
04-18-2019 04:31 PM
@Richard wrote:The RAW images are stored on the memory card in your camera.
Firstly, Richard, thanks for taking the time out to respond. Secondly, no. Whilst I can successfully capture RAW manually, without the use of the Canon Connect WiFi, the Canon Connect Live Shooting will not take/store the RAW, nor my other settings.
Richard I’ve just double, rechecked on the Screen on my SX60HS that the captures taken using the Canon Connect Live Shooting do not Capture RAW. To assist us I’ve taken snap of the Screen for you. The Camera was set for RAW and definitely not AWB. I never shoot AWB 😉. Also, I don’t know why my ISO should be 1000. And why “P” mode? Here’s the Screen Grab:
If I’ve done something dumb, please advise?
04-22-2019 11:38 AM
Whether the image is RAW or not has nothing to do with the AWB setting.
04-22-2019 12:00 PM
@kvbarkley wrote:Whether the image is RAW or not has nothing to do with the AWB setting.
Agreed. But I don’t want it. And yet it is a setting I don’t wish, nor an ISO of 1000 nor P mode. From what I’m seeing this software will stubbornly apply those settings regardless of my wishes.
I’m supplying my evidence-based results hoping somebody, also with an SX60hs, can either confirm or deny the results I’m getting and to learn if there is a solution.
04-22-2019 11:49 AM - edited 04-22-2019 12:11 PM
Hello, Grazie!
We recommend reaching out to support for one-on-one assistance with this. Our US-based team can be reached at 1-800-OK-CANON (800-652-2666).
If you're outside the USA, you'll need to reach out to support in your country/region by clicking HERE.
04-22-2019 12:05 PM
04-22-2019 12:12 PM
Sorry about that, it was an HTML error. I've fixed it!
For reference, here's the link: https://global.canon/en/support/
04-22-2019 12:22 PM
Stephen thank you.
What I’d dearly like to here if this RAW Shooting is supposed to happen with the Live Recording option through WiFi? If somebody knows that that it does or doesn’t would be a result.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
