09-22-2014 05:10 AM
Hello!
i have a problem with program Digital photo professional, when i want export images from RAW format to JPG.
The problem is, that quality of image is much more worse, then in RAW format in DPP. JPG looks blurred and fuzzy.
IMAGE LINK:
Please check image, on the left side is print screen from RAW in DPP, on the right is exported JPG from DPP.
I want export JPG with the same quality as i see in RAW
Is there anybody to help me?
Thanks a lot.
Vit
09-22-2014 06:49 AM
What settings and steps are you using when you convert to JPEG?
09-22-2014 07:10 AM
1. open *.CR2 (raw file) in DPP
2.file/convert and save
3.type of file - EXif JPEG (JPG, JPEG)
4.image quality 10
5.output resolution 350dpi
6.check - embed icc profile in image
There are not another settings, so i dont know, why has exported JPG so bad quality...
When i open *.CR2 file in PS5, i see the same bad quality as exported JPG from DPP, but i read, that PS5, cannot
open CR2 file in best quality, because PS5 doesnt have all function, that have DPP.
I tested it on two PC, so problem is not only on my PC...
Thanks.
09-22-2014 07:39 AM - edited 09-22-2014 07:40 AM
09-22-2014 07:43 AM
No, resize options is not checked.
About print - i will try it.
Maybe, something wrong is with camera options...
Could i send to you *.CR2 file and you try it? if you have this problem too..
Thanks.
09-22-2014 07:46 AM
09-22-2014 08:32 AM
Is the screen shot from DPP's own display of the JPEG file, or were you using a different editor?
09-22-2014 09:01 AM
yes, both screen"s are from DPP, on the right is exported JPG, which is open in DPP..
09-24-2014 10:10 AM
Get Lightroom from Adobe !
09-25-2014 04:34 AM
I will try lightroom, but i dont think, that the problem will be solved with new software.
Just dont understant, why is this problem with DPP, because i think, its a good program supplied with canon camera...
